1d cluster array replace value in a 1d boolean array (without using Loop)
Hi ,
is there a way to replace the values (string , boolean) ​​of a 1D array Cluster with value of 1D boolean array without using loop ?
Simone
(2,400 Views)
Nope.  Have fun with the FOR loop.
GCentral
(2,394 Views)
What is wrong about using a loop? Your question is analogous to asking: "Can I drive a car without wheels?"
Rolf Kalbermatter
My Blog
(2,381 Views)
The problem is about speed and cpu.... using "Replace Array Subset" could be the right solution but I do not know how....
(2,372 Views)
Replace Array Subset requires that the array elements are type compatible with the elements that you want to replace. That seems not the case in your example.
And the For Loop is anything but slow. How many billion elements do you expect your array to have to worry about performance of the for loop? With the type definition of your example even a ready made LabVIEW function would have to do internally a for loop too, since the boolean data inside the original array can not be in a continous memory area.
Maybe if you show us what you try to do with the for loop we can understand better what your concerns are. As it is from the front panel image alone it is really hard to understand what your imagined problem might be.
Rolf Kalbermatter
My Blog
(2,363 Views)
