NI Home
Cart Cart | Help
You are here:
Reply
Member
Lydecker
Where can I download LabView Toolkit for NXT
[ Edited ]
Where can I download the LabView Toolkit for Lego Mindstorms NXT to use with LabView 7.1? I would like to create my own block.
The NI website claims on this page http://zone.ni.com/devzone/cda/tut/p/id/4435 that this is the link to the download https://lumen.ni.com/nicif/us/evallegotoolkit/content.xhtml however it is a lie as it takes you to the download for NI LabVIEW for LEGO® MINDSTORMS which is not the same product (and does not support making blocks for the NXT-G Software).
Is there anywhere I can get a copy of the old toolkit, or are you saying it no longer possible to create your own blocks for the NXT-G software (that I would find hard to believe.)
Thank you.
Member
Jack._W
Re: Where can I download LabView Toolkit for NXT
Hello Lydecker,
On the same page you describe seeing the download for 'NI LabVIEW for LEGO® MINDSTORMS' there is a drop down section for downloading the module on it's own without LabVIEW. Have you tried this?
I believe this is all you need. After a restart you should then be able to access the block wizard In LabVIEW, select Tools»NXT Module»New NXT Block Wizard
Full instruction on the steps needed to create a block are in the following document -
Creating LEGO® MINDSTORMS® NXT Software Blocks- ftp://ftp.ni.com/evaluation/mindstorms/NXT_Creating_MINDSTORMS_Blocks.pdf
Hope this helps
Jack. W
Applications Engineer
Member
流年似水
hello,I have installed LV2011NXT,why tool>......   have not NXT module?
Active Participant
MahdiehG
If this is a new question I would recommend that you create a new thread. Also if you are more descriptive about your problem in the initial post it will help everyone in the community to answer your question.
Mahdieh G
National Instruments UK&Ireland
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
