LabVIEW Embedded
how to program the LPC2368 and LPC2468 using microprocessor SDK?
Hi
where to start? I have not found on the site of corresponding materials.
thanks for the help
(8,848 Views)
Accepted by Sergiv
Hi Sergiv,
I would suggest taking a look at the following document: LabVIEW Embedded for ARM Porting Guide - Chapter 1: Introduction.  It is a generic document that will explain the process of porting to any microprocessor.
If you have LabVIEW Embedded for ARM module, I would suggest that you take a look at one of the shipping templates.  There is a template already build for the LPC2468 that you should use.  And if you don't have the module you should download the evaluation version to get the template and save yourself a bunch of time.
I hope this helps.
Justin Parker
Product Support Engineer
(8,813 Views)
Thanks for your reply!
I do not have LabVIEW Embedded for ARM module.
if work only with microprocessor SDK, I want Keil?
(8,789 Views)
Hi Sergiv,
I'm afraid that something was lost in translation.  Are you asking if you can use the Keil compiler with microprocessor SDK?
Justin Parker
(8,776 Views)
Hi.
I have installed microprocessor SDK, but not installed Keil compiler. Keil compiler necessarily needed?
(8,769 Views)
Microprocessor SDK makes the C code from the LabVIEW code.  Once you have that you need a compiler to put in on the LPC2468.  Keil is the compiler that we package with the LabVIEW Embedded of ARM, and is what I would recommend since we have already done a bunch of the work for you.
Justin Parker
(8,754 Views)
