12-14-2013 04:58 AM
Hello all,
I am looking to develop embedded application with help of labview programming
Started with Lm3s8962 evaluation board.
So i would like to know
1 Advantages of using labview in embedded application when compared to c ?
2 Can we deploy the code in any kind of controller by writting drivers for it ?
01-30-2014 07:20 PM - edited 01-30-2014 07:37 PM
hello, the LM3S8962 microcontroller is a good sispositivos for developing applications of medium complexity, according to your questions:
1. if you work applications with embedded systems will save labview time in prototyping, we know that if you work with a company specific microcontroller, you must learn the language with which you are working Asm, Basic, C, then if you change hardware again start adapting your code in the libraries of the new compiler. Labview does not happen.
2. Labview only works with some microcontroller manufacturers and specific models.
