How to use "Next" button to control prgram steps?
Hi all,
I'm a beginner in Labview programming and I need some help on creating this interface control.
Attached is the program and a jpeg of the frontpanel.
I would like to use the "next" button to control the next sequence of entring the parameters(ie fm/am, Mhz,dBm etc.) and aquisition of SINAD.
This means that only when the user presses "next" then the next frequency parameters will be entered and SINAD measured.
I hope someone out there understands what I mean and would be able to help me on this. I cant seem to get the attachments to work together with this post.
(3,955 Views)
Please, please, please read this: Application Design Patterns: State Machines
and stop relying on sequence structures so much.
(3,951 Views)
Thanks for the quick response, but I need each frequency with its other settings to flow in a specific order with just the "next" button to control when the user wants to change to the next frequency step. Is state machine still able to achieve these results?
I know my program is too simple thats because i'm really a beginner who just started learning labview using a guidebook.
Really appreciate all your help!
(3,941 Views)
Hi, I manage to utilise the use of state machines already, however, it does not solve my problem of using one same "next" button to switch to the next state. I tried using local varables but it is not allowed in the event structure, are there any other alternatives?
(3,925 Views)
You must not have implemented it correctly. Please post your latest code.
(3,919 Views)
