08-16-2005 08:46 AM
08-17-2005 11:06 AM
Currently you can only configure GPIB-ENET/100 devices using "dotted quad notation"; you do not have the ability to specify an extended, larger IP address like you would be able to on a IPv6 network. Because of this, if your network will be communicating solely via IPv6, I don't see this working. If you will be on some kind of dual network that allows both IPv4 and IPv6 you may be able to still communicate with the GPIB-ENET/100s, however you will need to check with your IT professionals to find out whether or not your system will allow for the IPv4 dotted quad IP addresses.
Otherwise, echoing Chris' question, has anyone out there tried this?
Logan S.
08-17-2005 11:25 AM
