Error: Property Node (arg 1) in VISA Configure Serial Port
I am getting this error as ""Error: Property Node (arg 1) in VISA Configure Serial Port""
in my VI
I am not able to locate the problem..
please help out.
(6,458 Views)
Did you specify a VISA resource name? If that control is empty, I get error 1. If I specify an invalid name, I get error -1073807343.
Also, ou do not need the sequence structure.
Lynn
(6,450 Views)
I'm also encountering this issue; did you ever find a solution?
(5,568 Views)
The solution is to make sure you have the COM port selected in the visa control
(5,549 Views)
