VISA resource name problem with Hameg HMS1000
I have a HAMEG HMS1000 spectrum analyser and i want to communicate with it using NI VISA and SCPI commands.
First i created a driver for my device with the informations given here : http://www.hameg.com/0.563.0.html. my device showed in the device manager under  "NI-VISA USB Devices"
The problem is when i launch NI MAX i can see my device and communicate with it using "VISA TEST PANEL" but when i switch to labview, visa resource name doesn't show the name of my device.
did i do something wrong? please help
(4,694 Views)
Did you use the VISA Wizard to create a USB RAW interface? That is seldom a good idea. Are you sure you weren't supposed to create a virtual com port? Most instrument vendors define a USB connection as either USBTMC or a serial connection.
p.s. Your link is bad.
(4,684 Views)
well yes i used the NI VISA Driver wizard to create a RAW usb interface, if it isn't much of a good idea should i use the windows drivers given by the vendor ? thank you again
(4,679 Views)
Accepted by topic author nowever111
You should always use the driver provided by the vendor.
(4,670 Views)
