08-19-2022 01:26 PM
Hello Labview'ns
I am trying to update test datas to a database via Rest API . I am able to execute Get, post functionality well. Recently got a requirement to update certain blocks via patch.
Could some one help me here to implement patch using LabVIEW?
If someone already implemented the same , expecting some hints .
10-05-2022 02:45 PM
Looks like it's not supported. Under the hood, NI uses a curl library, so you'll probably just have to implement a solution that calls curl from the cmd line. I'm about to do the same. Annoying that they don't break out all the methods.
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Support-PATCH-verb-for-HTTP-requests/idi-p/3745891
11-29-2022 08:23 AM
This is implemented in LabVIEW NXG. I have converted it for Labview 2020 and its working fine.
12-01-2022 03:37 PM
Ah. I haven't even looked at NXG.
Doing a quick search, it doesn't look like it's possible to convert it. Can you point me to a page that instructs how to convert, or share the library you converted if it's not too much trouble?
