Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
07-13-2016 08:34 PM
I want to use PCI-1588 as a master of 1588 version 2 (Ethernet multicast) node .
But sample program is only for 1588 version 2 (UDP/IPv4 multicast) node.
Please give me an information on how can I setup PCI-1588 as 1588 Ethernet multicast nodes.
Cheers.
Tak.
Solved! Go to Solution.
07-15-2016 05:23 PM
Hi yamaoka,
NI-Sync, the driver that supports the PCI-1588, currently only supports layer 3 packets. If you have any additional questions, I'd recommend posting to the PXI forum. I think you'll have better luck there with questions on the PCI-1588.
Thanks!
We'll be in touch soon!
