FieldPoint Family
RS 232 port to communicate between cFP 2100 and Multiple cFP 1808
Hello All,
I am using one cFP-2100 (controller) and two cFP-1808 (network contoller) for a project.
All the three devices have Ethernet port, so i can connect to a network switch for communicating with the Host PC.
My question is:
All the three devices have Serial Ports (RS 232) too, Can i use those ports to communicate between the three devices (1 controller and 2 Net. controllers) and use the ethernet port in the controller (2100) only for communicating with a Host PC?
If this is possible, how to do the RS 232 cabling ?
Regards
John
-John Theodore
Certified LabVIEW Architect, Certified TestStand Architect
(5,676 Views)
Hi bjsprem,
You can connect network modules to the controller with serial.   This KB shows how to do this.  Hope this helps!
--Starla T.
(5,666 Views)
