02-16-2016 10:49 AM - edited 02-16-2016 10:51 AM
Looking at this post, the quoted text is not delimited by horizontal lines, however, when I edit it, the lines are there.
Also, the html code shows them. I am not sure why the post has a darker background. Could it be that the lines have the same color?
Here are a few horizontal lines for more testing:
Aha! They are now light grey. They should be darker!
(This is on chrome).
02-16-2016 02:23 PM - edited 02-16-2016 02:25 PM
Hi altenbach,
Thanks for reporting this. There is a css issue causing the horizontal lines to appear lighter in color (#eee) than normal (#989898) when inserting using the button in the text editor
This does not happen when you use a horizontal line inside of a <blockquote>, which is what is inserted into a post when you use the quote button above the text editor.
Example:
I'll follow up internally to get this addressed.
As for why your post has a darker background, you'll see this when the URL is higlighting the particular post. For instance:
This is highlighting a particular post: http://forums.ni.com/t5/Feedback-on-NI-Discussion-Forums/disappearing-horizontal-lines/m-p/3254107#M12608
This is the same topic, but no post is highlighted: http://forums.ni.com/t5/Feedback-on-NI-Discussion-Forums/disappearing-horizontal-lines/td-p/3254107
I'll post back when I have an update on the line color issue.
04-14-2016 11:27 AM
This issue has now been resolved.
