Dynamic Signal Acquisition
how to configure digital tacho in SVMS using PCI-6143?
hi all,
i am trying to develop shaft vibration monitoring system using S&V meas. suite7 and labview8.6 having polar graph, program attached with few emendmends to DSA example.
problem is that how to cnfigure digiat tachmeter using counter of 6143 as i want to have 4 analog continuous inputs (NCDT) along with the counter edge counting info (continuous) for digital tacho processing to caculate phase.
when i defining a task for counting edge continuously.... it ask for external clock to configure with, which is problem.
how can i do this project with one board 6143 with digital tacho.
any one would emend this code to execute with 6143.
thanks
Masood
(6,568 Views)
Hi masoodtahirpk-
     The 'external clock needed' error has something to do with the configuration of your counter channel.  Will you right-click on the task constant and select Generate»Configuration and send us a screenshot of what is going on there?
Gary P.
Applications Engineer
(6,551 Views)
