03-17-2010 02:06 PM
I have ASCII data in .xls file.. it is of 65000 rows and 9 columns...
we have to read that data using LABVIEW from 23rd row and we should plot a grapph between 1st column and 8th column , and 1st column and 9th column. After dat we have to count the number of pulses present in that gragh for these saparate waveforms and maximum and minimum values of each pulses...... Here I am attaching the .xls file too
03-18-2010 01:04 PM
To read data from Excel, you would want to take a look at the Report Generation Toolkit for Microsoft Office or use ActiveX to read in the data. Once you have the data read into LabVIEW what you are trying to do should not be too hard.
-Zach
03-18-2010 02:28 PM
Hai ,
I wrote one code for that using spread sheat tool.. I am attaching that here.. please look at that..
03-19-2010 11:33 AM
What part are you having trouble with? I'm not exactly sure why you're using the Delete From Array function instead of Index Array or Array Subset.
-Zach
03-19-2010 12:47 PM
03-22-2010 10:23 AM
Hey Avinash,
Were you able to bring the data into LabVIEW using the Read from Spreadsheet VI? As in any programming language, there is no single way to accomplish a task. So, with what you have, were you able to extract that data that you are interested in? As Zach was saying, using the Array Subset VI is another valid way of getting a particular section of your array.
03-22-2010 12:02 PM
03-22-2010 12:50 PM
03-23-2010 09:52 AM
If you press Ctrl-H, you will bring up the Context Help window. Once this window is open, you can hover over your broken wire and it will describe why this connection cannot be made. In your case, you can see that the datatype coming from the source is not the same as the datatype going to the sink.
The XY graph is expecting a cluster of 2 double elements and a 1D array of double elements. The image below shows 2 double constants and 1 array constant of doubles being bundled into an array and this does not result in a broken wire.
I hope this helps!
03-24-2010 12:32 PM
Hai,
I have corrected that .vi file please check it once, its not showing the exact input of .xls file and it is showing some unwanted signals, I am attaching the file here
