Driver Development Kit (DDK)
X series PCIe-6351 encoder reset
I am working on the X series PCIe-6351 encoder input by using an example gpctex4.cpp from X series DDK. It seems counting fine. However, it doesn't reset the counter even it is setup as follow:
counter->Gi_Mode_Register.setGi_Loading_On_Gate(nC​ounter::kReloadOnStopGate, &status);
counter->Gi_Mode_Register.setGi_Trigger_Mode_For_E​dge_Gate(nCounter::kGateLoads, &status);
and
counter->Gi_Counting_Mode_Register.setGi_Index_Mod​e(indexMode, &status);  //indexMode = nCounter::kIndexModeSet;
Can anyone tell me what is wrong? Do I miss something?
Larry
(8,331 Views)
What are you doing to reset the counter after you make these changes to the example?  For instance are you connecting a 5V signal to the Z input (PFI2)?
With your changes, connecting 5V to the Z input results in the encoder seeing a 0 degree rotation change....which is a reset.
Steven T.
(8,304 Views)
counter->Gi_Counting_Mode_Register.setGi_Index_Mod​e(indexMode, &status);  // indexMode = nCounter::kIndexModeSet;
Just closing the loop in case others search and find this post later. Larry shared his resolution in another thread:
http://forums.ni.com/t5/Counter-Timer/X-series-PCIe-6351-encoder-reset/m-p/1996057#M10458
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(8,297 Views)
