08-21-2013 01:07 PM
Thank you! I'll give it a try!
08-21-2013 01:27 PM
Good luck with all of your work and take care!
08-23-2013 09:43 AM
In your snippet above: the write is outside the while loop, it that correct? And, what's the vi with the "?" and the digital waves inside the while loop?
08-23-2013 10:20 AM
The data being written is stored in a hardware buffer so it does not need to be in the while loop. The VI inside the while loop is a DAQmx Is Task Done.vi. Used to make sure the device is in a good state before exiting the while loop and clearing the task.
