Data Acquisition Idea Exchange
BertMcMahan
Create simulated version of real device by right-click in MAX
Status: New
Often I need to create a simulated version of a real device in order to debug something. It would be nice if I could right-click on a real device in MAX and select "Create simulated version of this device", and it would create a simulated version of the device I'm running. This isn't so bad with standalone devices but it could make simulating modular devices easier and reduce the likelihood of a mis-click making an incorrect simulated device.
3 Comments
razzik
Check the tutorial "NI-DAQmx Simulated Devices"
Raz 🙂
BertMcMahan
razzik I understand how to create the simulated devices, the idea is to have a shortcut to duplicate a piece of physical hardware into a simulated one by right-clicking on it. When doing multi-slot cDAQ chassis it would save a few steps to just right click and pick "Duplicate as simulated device" than to have to create a new empty chassis, then configure each module separately, etc.
Just a QOL idea.
Peter-daq.io
Agree 100%. If a device is disconnected, creating a simulated version from it should be a single action. This way, one action can create a simulated version of the device, including its names.
My suggestion:
If a device is disconnected, allow a right-click action: "Create simulated device with these settings". Store the original device as shadow-copy and replace the simulated one once the real device is plugged in again
CLD | Alliance Partner | Web data storage and visualization | daq.io
