Data Acquisition Idea Exchange
About Data Acquisition Idea Exchange
Have an idea for new DAQ hardware or DAQ software features?
  1. Browse by label or search in the Data Acquisition Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see implemented!
Add MSI/MSI-X interrupts support to VISA
Hi!
PCI Express bus became more and more popular.
PCIe has a new type of interrupts - MSI/MSI-X.
Today VISA driver is able to work only with old style interrupts (Legacy).
Let me explain the main difference:
Legacy interrupt mask intA/B/C/D signals (these signals was in PCI bus, but not exist in PCIe bus).
These signals (for PCIe actually packets with Message setA/B/C/D) are shared between all PCIe devices.
So VISA driver spend a lot of time when it looks who produced this interrupt.
MSI interrupt is actually a Memory Write packet to preallocated address.
In this case VISA should already know which device produced this interrupt.
Also MSI interrupt can contain different interrupt vectors inside of Memory Write packet. So it would be very helpful to get access to vector value too.
Requesting MSI/MSI-X interrupts support to VISA driver.
Thanks a lot!
