08-15-2005 10:37 AM
08-16-2005 04:34 AM
Hallo Mr. Bohm
The easiest way is probably just to call two different scripts. One ScriptNameWithHardware and one ScriptNameWithoutHardware.
It's also possible to call commands other than ScriptStart from the command line. For example /Cb1:=true would cause the DIAdem global variable b1 to take the value true. You could theoretically use this to call a user command with a parameter. You'd have to register your user command beforehand though. The registration of the user commands is saved in the desktop file.
Hope that helps,
Myrle
08-16-2005 10:47 AM
