06-21-2006 02:27 PM
In a graph template I want to insert an x-axis constant line at the minimum measured value on the y-axis. I have succeeded in printing the numeric x value in text on the graph by using the formula:
str(ChD( find (“Vacuum_Smooth” -CMin(cno(“Vacuum_Smooth”))<0.001), 'Time1”)
However, this formula does not work when I insert it into the VBS code of an autosequence.
D2CCONSTX =str(ChD( find (“Vacuum_Smooth”) -CMin(cno(“Vacuum_Smooth”))<0.001), (“Time1”)
As written, I get the error message:
CHD(“FALSE”)”,” for the second index or parameter expected!
How can I accomplish this task in the autosequence VBS code?
06-21-2006 03:46 PM - edited 06-21-2006 03:46 PM
str(ChD( find("Vacuum_Smooth = CMin(Vacuum_Smooth)"), "Time1"))
For D2CCONSTX you have to set a expression wich will deliver a double value. No str() is required! This expression must be encapsulated in @@ to show DIAdem that it is not a value string. The code line must look like this:D2CCONSTXNAME = "@@ChD( find(""Vacuum_Smooth = CMin(Vacuum_Smooth)"" ), ""Time1"" )@@"
As you can see the " in the first code example are replaced by "" because it has to be a " after VBS had evaluated the string. If you put the value string in D2CCONSTX
you have to update the layout on every change.Message Edited by Twigeater on 06-21-2006 10:51 PM
Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
