08-18-2005 10:54 AM
08-19-2005 05:25 PM
Hello Stroby,
I see what you mean. For the first part, copying and pasting a table from Word into a Text Object, I saw better results when I used a thicker line. Still, when exporting the TDR to a PDF, some of the table’s lines did not make it. I saw similar results when exporting to other formats as well.
I’ll see what I can find out and let you know when I do. Thanks for the heads up.
- Eric
08-20-2005 12:36 PM
Hello again,
Turns out, the DIAdem R&D team is well aware of this issue. In fact, the problem is (will be) fixed in the next release of DIAdem. I have seen it work beautifully with my own eyes in a recent build. Granted, this doesn’t help you right now. However, if you are patient, you will have this functionality in the future.
Eric
