DIAdem
How to fix path settings (General Settings)
Hello
In General Settings -> Path settings I defined the "SCRIPT user path" which I use for calls from a custom menu in DIAdem 10.
But after loading / open a script from a different directory this path settings changes!
This means the calls from my custom menu don't work anymore.
Is there a solution for this?
James Code
(3,373 Views)
Hello James!
The only way I know is to set the library path to your script path. The setting is stored in the DDD and will be restored on startup and not changed by any action. If this doesnt work for you you can use a Windows environment variable and get this with the GetEnv command in you custom menu call.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,365 Views)
Hello Matthias
Thank you for your answer.
The libary path I tried with no success. The calls like the one below do not work:
  Call MenuItemInsert(Window, cstr(MenuItemCount)&".3", "MENUITEM", "Experiment", "Call ExtProgram(AutoDrvUser + ""MyExtApp.exe"",""ExperimentClass"")")
Windows environment variable would work, but makes deployment not that easy.
Maybe I have to write my own settings file ... is there a preferred way to do this?
James Code
(3,348 Views)
Hello James!
Please change 'AutoDrvUser' to 'AutoDrvLibr' in your definition.
Matthias
Matthias Alleweldt
Twigeater?
(3,346 Views)
Hi Matthias!
Excellent! works perfect. Thank you.
James Code
(3,341 Views)
