DIAdem
Curve Transformation in Report
 I'm struggling to figure out how to use the curve transformation options in the report tab.
Basically I have some unfilterered channels that I would like to plot with a CFC1000 filter applied. This appears to be the option I need, select the channel, apply the filter to the channel only when it's plotted.
Any advice?
Message 1 of 8
(3,598 Views)
The following DIAdem Help documentation for event definition provides some context for how to populate those fields.
'Event Definition'
http://zone.ni.com/reference/en-XX/help/370858M-01/dlgpresent/graph_dlg_menu/dlgeventparams_dialog/
Specifically, the event definition is tied to a user command. For example, if you select 'Current event definition (recommended)', DIAdem will execute the user command you put in the 'According to new definition' text box. For either option, the user command you select must already be registered with DIAdem.
Message 2 of 8
(3,538 Views)
But that's not totally helpful. Anyone else?
Message 3 of 8
(3,410 Views)
Hi Tamer,
Check out the shipping example, "Extracting Bits Using Curve Transformation".
Brad Turpin
DIAdem Product Support Engineer
Message 4 of 8
(3,387 Views)
Thanks Bob,
I think this is a good starting point. It's a bit complex, but I'll see if I can dissect it to get it to do what I want.
Message 5 of 8
(3,346 Views)
Bump. Anyone else have any ideas?
Message 6 of 8
(3,048 Views)
What happened when you started from the shipping example recommended by Brad?
Highest Regards,
Paul
Message 7 of 8
(3,034 Views)
I didn't have any luck getting it to work.
Message 8 of 8
(3,029 Views)
