Counter/Timer
PXI-6624 only writes one sample in pulse mode
Hello all
I am trying to write a pulsetrain to the counter output of a PXI-6624, however only the first sample is ever written.
My pulsetrain has 50 samples, and with simulated hardware the output "number of samples written per channel" matches that. If I build the application and run the program on the target system it only outputs one sample indefinitely and also "number of samples written per channel" is always 1.
I tried adjusting the value for "numSamplesWriten" in "DAQmx Write (Counter 1D Time 1Chan NSamp).vi" to a non-zero value without any influence. The timing is set to 50 samples in continuous sample mode with implicit timing.
What am I missing, how do I get the counter to go through the array of samples one by one to output the desired timing series?
Thanks in advance,
Raphael
(3,080 Views)
Accepted by topic author raphael.wittwer
I think the 6624 is an older model with an NI-TIO timing chip that doesn't support buffered pulse train output.   The best you can do is to change on-the-fly with software timing.
Note also that finite pulse trains will occupy a 2nd counter known as the "paired counter".   The pairing is set internally, cannot be changed, and goes like:
0<-->1
2<-->3
4<-->5
6<-->7
A newer card like the 6612 can do buffered pulse train output with hardware-level timing, *and* finite pulse trains no longer occupy a 2nd paired counter.
-Kevin P
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW? (Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
(3,067 Views)
Hello Kevin
thank you for your reply. It really seems it is not possible with this hardware.
Since the hardware is already fixed I will have to think of something else.
Thanks, Raphael
(3,001 Views)
