Components
Tag Configuration Editor (TCE) for Machine Control
The e-mail address in my previous post has been corrected.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
Message 11 of 47
(11,078 Views)
I am trying to open the 'Simple Machine Control Example'  MCA_Tag Configuration.xml file and I get the error below and after that I have to go to the task manager and end the TCE.exe.  Any help would be great.
Steve
Error 537020 occurred at an unidentified location
Possible reason(s):
While loading a configuration file an error occured.
The class tagRoot tried to make the class ReadTWriteF a subnode, but is not in the allowed subNode data
Message 12 of 47
(10,508 Views)
Hey Steve,
What versions of the example and TCE are you using?  I just downloaded both tce_installer_202.zip and simplemcaexample202.zip directly from the respective webpages, unzipped and installed tce_installer_202.zip and unzipped the simplemcaexample202.zip.  I ran the TCE, selected File>>Open and select the newly unzipped MCA_Tag Configuration.xml.  This doesn't give me any issues.  Is this the process you are following?  Did you change anything in the XML file?
I did try and open MCA_Localization.xml, which gave me the error you explained.  This makes sense as this xml file is intended for a different configuration editor.  It did also hang the TCE like you described.  I will add that to our internal list to make sure it gets fixed in future releases.
Daniel Eaton
Systems Engineering
Embedded and Industrial Control
Message 13 of 47
(10,504 Views)
After an uninstal and reinstall, it works.
Steve
Message 14 of 47
(10,500 Views)
Hey, TCE and the rest of the Reference Architecture is great! It saves lots of work developing our own mechanisms to handle the many underlying tasks. Thanks so much!
It would, however, be nice in the TCE if we could easily reorder Tags in the tree, or move a tag from one folder to the other by dragging and dropping.
-Nate
Message 15 of 47
(10,353 Views)
Actually the drag drop feature and reordering is already in the TCE, you just have to press the control button.  I intended to put text on the front panel that would say as much, but I forgot.  Hope that helps and thanks for the feedback, and if you have any more ideas that would be great.
Brian K.
Message 16 of 47
(10,347 Views)
I frequently experience hangs with the TCE where I have to End Task using the Windows Task Manager. It occurs at least once or twice a day each day I am using the TCE. Does this happen to anyone else, or am I doing unusual things with it?
Message 17 of 47
(10,303 Views)
Can you trace it to any particular action?
If we can't, then maybe we should run the source code instead of the EXE, and hopefully the hang can be debugged just by seeing where the code gets stuck at?
Brian K.
Message 18 of 47
(10,298 Views)
I did recall a bug that looks like a hang.  If you hold the control button down (or any button down) while the focus is on the tree control, it fires many events. And those events take a long time to get processed (like a minute), so it appears to hang.  If you wait like 2 minutes do you regain control?
Brian K.
Message 19 of 47
(10,293 Views)
Hi all,
I've just noticed that the TCE source code has a dependency from Unicode VIs that are expected to be placed in the <user.lib>\Tools\Unicode folder. In order to solve this dependency you must dowload them from this page:
https://decibel.ni.com/content/docs/DOC-10153
the attachment you have to dowload is LV_Unicode-110-lv2009.zip
Fabio
Fabio M.
NI
Principal Engineer
Message 20 of 47
(8,565 Views)
