Hi Andre
The NI CAN hardware does not have the ability to access the full raw CAN frame. This is because of the used CAN controller (Philips SJA 1000 on Series 2 CAN hardware) does which does not provide all of this information. However, the following data is provided:
- Arbitration ID (11 or 29 bit)
- Data Length (DLC)
- Remote Frame Flag (RTR)
- Data (0-8 byte)
As you are interested in the raw/unconverted CAN data, you should focus on the NI-CAN Frame API, as the NI-CAN Channel API tries to abstract these information.
With Series 2 CAN hardware, you have read access to the receive/transmit error counter. Take a look at the ncGetAttr function (Frame API) or the GetProperty function (Channel API) and query the ‘Series 2 Error/Arb Capture’ attribute or the ‘Interface Series 2 Error / Arb Capture’ property for that. You can find more details on how to read the returned data in the help for the two functions.
-B2k
