NI-CAN Channel API on LIN?
My application was developed years ago using the NI-CAN Channel API on PCI CAN cards. I have successfully used that old application on newer XNET CAN cards by installing the NI-CAN Compatibility Library. Here's my question: Is there a way to use that old app with an NI 9866 LIN module, perhaps through the NI-CAN Compatibility Library?
(4,709 Views)
Hi ClausB!
Unfortunately, from my current understanding, the compatibility library that you are discussing does not support LIN.  More information about what is supported can be found in this document:
What Interfaces does the XNET Compatibility Layer Work On?
http://digital.ni.com/public.nsf/allkb/846160FE77DEA0DE862579C10075215E?OpenDocument
Thanks!
Tucker
Applications Engineering
(4,645 Views)
