BreakPoint
Monthly bugs, July 2009
This is the continuation of the June 2009 bug thread.
The rules are as always:
Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  1. One post/bug!
  2. One bug/post!
  3. No discussion of bugs. All discussions of a bug must take place in the original linked thread.
July bugs everywhere!!!
Message Edited by Mathan on 07-03-2009 03:03 AM
Message 1 of 12
(10,985 Views)
"data entry" settings behave incorrect for numeric controls in LV 8.6.1:
http://forums.ni.com/ni/board/message?board.id=170&message.id=421753&jump=true
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 2 of 12
(10,945 Views)
This bug has already been reported LV 8.6.1 Bug in Data Entry Limits for controls and fixed in 8.6.1f1
Message 3 of 12
(10,932 Views)
See this thread for more description and steps to reproduce.
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=420500#M420500
After changing the Read Lines check mark in the right click menu, the compiler doesn't correctly check the wire types coming out of the VI to the string array indicator or string indicator (depending on which was initially wired up and the new mode set for the VI.)
Message Edited by Ravens Fan on 07-07-2009 09:22 AM
Message 4 of 12
(10,931 Views)
Message 7 of 12
(10,802 Views)
As described here, the Read Key (Path) does not return correct path for key values that begin with "\\\\" in a config file.
CAR# 179652
Message 8 of 12
(10,784 Views)
IPE structure replacing the wrong element under certain conditions:
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=425606#M425606
I haven't checked it myself, so I'm not sure of the details (version, etc.).
___________________
Try to take over the world!
Message 9 of 12
(10,732 Views)
Message 10 of 12
(10,691 Views)
