BreakPoint
Monthly Bugs (June 2006)
This is the continuation of the May 2006 monthly bug thread.
Rules:
  1. Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  2. One post/bug!
  3. One bug/post!
  4. No discussion of bugs. All discussions of a bug must take place in the original linked thread.
  5. Frogs are allowed to report bugs.
Chilly Charly    (aka CC)
(7,057 Views)
You can't pick up a color when a color box is placed at the window bottom, as reported by Rashig here
(7,053 Views)
LabVIEW 8.0.1 (feature not implemented in LabVIEW 7.1 and probably earlier)
The automatic format typing for time formats in "scan form string" does not survive the boundary of a case structure or event structure.
Message Edited by altenbach on 06-16-2006 05:44 PM
(7,017 Views)
Well, I know it is July 6th .. but I could not find the July buglist ... so I'll post here .... (And usually these monthly list are closed at the end of the month and this one is not closed)  There is a bug in the PDA module for Pocket PC ... when placing a slidebar indicator on the front panel and updating it in a loop, there is a memory leak that will eventually crash your machine if left in the loop without closing the front panel .... outlined in this thread ... NI confirmed.
This also happens with a few other indicators. (outlined in the thread)
Greycat
(6,937 Views)
Well, you could just create a new July bug list according to the template, then close the old one with another post. 😄
There are no special privileges needed for any of this.... 😮
Most likely, you'll even get some stars. 😉
The June Bug list is now closed.
Let's all meet in the July bug thread and exterminate these critters!
(6,922 Views)
Clearly, there are no more June Bugs 😄
Message Edited by altenbach on 07-06-2006 08:49 AM
(6,916 Views)
