Hi etudiant2007 -
WCDMA is not a trivial transmission scheme, and unfortunately there aren't any canned examples that I can provide to you. Your best bet is to start with the Modulation Toolkit to build the chirp packets that will be generated. I have some questions, too:
- Which version of LabVIEW are you working with?
- Do you have the Modulation Toolkit?
- What hardware are you using? (NI 5670 or 5671?)
I also noticed that you posted simultaneously to our French forum with a similar question. If you get any help in that language from your other thread, we'd appreciate it if you could post back here with things you learned, so English-speakers can gain from the knowledge too!
David Staab, CLA
Staff Systems Engineer
