03-02-2009 04:44 AM
Hello
My question is how to digitize Data using channel 0 and channel 1 of a digitizer simultanously. i have made two VI files for this running on 5142 channel 1 and channel 2 using two different anttenas but when i run one the other is stopped . or when i try 2 run both simultanoiusly error comes which says No proper handle found and the "niscope close.vi" blinks and one VI is stopped.
Regards
Madd
Solved! Go to Solution.
03-02-2009 06:34 AM
Hello Madd,
I modified a shipping NI-Scope example to write the attached basic example that demonstrates multichannel acquisition using NI-Scope. I have left the example very sparse on purpose to illustrate the "active channel" concept. There are two things you need to do differently:
1. Specify the active channels you want to acquire from.
2. Use one of the "multi waveform" polymorphic instances.
Please let me know if this helps.
Abhishek
03-02-2009 10:37 PM
Hello
Let me make my question more detailed. As we Know that channel 0 of 5142 is an OSP enabled/disabled channel.and channel 1 is a straight channel I want to perform real acquisition using channel 0(with OSP enabled) and a complex/real acquisition using channel 1 at the same time in the same Vi or in two different VI's running in parallel . R u getting my point. Also is it possible that I acquire one signal using channel 1 from RFSA configuration and other channel 0 from an external downconverter simultaneously.
Regards
Madd
03-03-2009 10:22 AM
The 5142 can't do a complex acquisition on channel 0 and a real acquisition on channel 1 at the same time. For that functionality you would have to synchronize with a second digitizer.
03-03-2009 11:19 PM
Hello
u forgot to provide justification. Ok lets look at thin in this way . i want to acquire both complex signals using both channels simultaniously
now how to do (keeping in mind the Questions above )
Regards
Madd
03-04-2009 11:36 AM - edited 03-04-2009 11:37 AM
Hi Madd,
The justification is in the block diagram of the 5142, and more specifically the block diagram of the OSP.
Notice that in the 5142, both CH0 and CH1 are routed to the Decimation or OSP block. See image below:
Now notice that in the OSP itself, both channel 0 and 1 are being used in the DDC for downconversion. See image below:
As you can see, both channels are being used for the OSP functionality even though the source of the data came from one ADC channel. To do this we essentially route the same information from ADC0 to both CH0 and CH1 and perform the OSP operation.
If you would like to use CH0 and CH1 independently, you will limit yourself to decimation only - Digital Downconversion and complex baseband will not be possible.
03-04-2009 11:42 AM
04-15-2009 11:30 AM
Hello Madd,
Because your question on this post is the same as on other threads, we would like to consolidate your posts to one thread so that everyone who is interested can follow the progress of your issue. All further activity on this issue will continue on thread linked HERE. Thanks.
Chris W
04-15-2009 11:35 AM
Hello Madd,
Chris W
