XY graph Multiplot with multiple X-Y axes
Here's the modified VI in LabVIEW 8.6.1.
Message Edited by Bill@NGC on 08-01-2009 03:19 PM
Message 11 of 16
(1,891 Views)
Ravens explained my problem well. I am also using LV 8.6.1f1
As Bill mentioned there is no need to wire it up for that 3rd plot & making it transparent. By simply adding the 3rd plot onto the front panel itself is working fine. I have checked.
 Thanks Kousy
Message 12 of 16
(1,867 Views)
Wierd. I'm following Ravens steps, but my second plot stays the same after i clear the chart. I'm using 8.6.1 so this could be a problem with 8.6.1f1. Will test it under 8.6.1f1 and 2009 and see how that goes.
/David
Message 13 of 16
(1,860 Views)
But I originally developed in LV7.1 for one of my application upgradation requirement. LV7.1 also suffers.
I am not sure how 8.6.1 works ok because 8.6.1f1 patch is a bug fixing for numerics default property behaviour. I could not visualize..
Kousy
Message 14 of 16
(1,855 Views)
ok, did some further tests (sorry if I'm a bit slow today, it's monday....) and this is what I found:
If you open the VI in the first post, then run it without configuring the second plot the described problem occurs (just like Raven said). Doesn't matter how you configure or save afterwards, the plot style reset when you clear the graph while running. It does so on 8.6.1, 8.6.1f1 and 2009
BUT if you instead configure the plot first, then run the VI the problem does not occur at all, in any verison I've tried on. Mucho wierd....
/David
Message 15 of 16
(1,848 Views)
Hi all
Just wanted to let you know that this has been verified as a bug and Corrective Action Request #181633 has been created for it.
Best Regards
David
Message 16 of 16
(1,801 Views)
