Additional Installers Page Blank and Disabled
Hello Friends,
First of all I would  like to thank NI & Veterans on maintaining such a vast and useful forum where we can find solutions to almost all of our problems.
I recently faced a problem while creating installer for my application (using for first time). I found that additional installers page required to add runtime engine and Daqmx Drivers was blank and even disabled (Please see the attached image). I tried to repair my Labview 8.2.1 Installation (I also have Labview 8.0 installed on the system) but could not rectify the problem.
Can anyone please suggest soultions or hints for my problem?
Shourya
Message 1 of 20
(4,816 Views)
Dear Friends,
Please reply
Message 2 of 20
(4,801 Views)
Has it someting to do with the below given Issue in Labview 8.2.1?
http://digital.ni.com/public.nsf/allkb/842DC4802B0A33AD862572E200592DAB
Please suggest
Message 3 of 20
(4,796 Views)
Shourya,
did you install LV in the default installation directory on your developement system? Do you have administrative rights?
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 4 of 20
(4,792 Views)
Dear Norbert,
Yes  I installed LV in default directory.
Yes I do have administrator rights.
Message 5 of 20
(4,786 Views)
Hm, this is odd. Due to your statement, you already followed the steps listed here.
Do you have any modules/toolkits installed? Does the issue occur only in a certain project or even in new ones?
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 6 of 20
(4,783 Views)
Seeing the link given by you, I think I will try to repair LV again and see the effect.Or maybe I should uninstall and reinstall again.
Yes have S&V Module installed and OpenG VI's.
This issue comes in all the projects even in almost empty ones. I checked that before.
Will let you know soon.
Message Edited by ssingh1 on 02-18-2009 04:04 AM
Message Edited by ssingh1 on 02-18-2009 04:06 AM
Message 7 of 20
(4,763 Views)
Still no luck.
I strongly beleive that this has to do something with installer source location.
Please see the attached file in which even the browse icon has vanished.
Any Thoughts, Please.
Message 8 of 20
(4,753 Views)
Here are a couple other things to try:
1) Check C:\Program Files\National Instruments\Shared\MDF\Manifests to see if it contains files
2) Enable CDK.EnableLog=true in the LabVIEW.ini file, restart LabVIEW, launch the installer build rule editor again. Retrieve log file from current user's temp folder. Log file name matches build spec name (e.g. My Installer.log).
Message Edited by Bob P on 02-18-2009 09:29 AM
Message 9 of 20
(4,734 Views)
 Dear Bob,
I tried you suggestions
1) Yes the directory is having lots of files.
2) I enabled the log File. When I tried to build the installer (which i had not done so far Smiley Tongue) I got the following errors
CDK_CreateNewWizard_Invoke.vi.ProxyCaller >>
CDK_CreateNewWizard_Invoke.vi >>
CDK_InstallerConfiguration_Editor.vi >>
CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >>
CDK_Engine_PreBuild.vi >>
CDK_Validate_DistParts.vi >>
CDK_DistParts_GetInstalledProducts.vi >>
NI_MDF.lvlib:MDFProdInfoList_Open.vi
And the build was unsucessful.
I am also attaching the Labview log file.
Message 10 of 20
(4,716 Views)
