Biomedical User Group Discussions
Problem with Load image from DICOM.vi
Hi all!
I have recently been having trouble with the Load image from DICOM.vi. I have tried using the example program located here: https://decibel.ni.com/content/docs/DOC-12784, as well as a more simple version I created, both of which are attached, as well as the Example DICOM images from Taylor S. Amarel. Every time I attempt to run the program, LabVIEW crashes. I have installed all necessary toolkits to run the Biomedical Startup Kit source code, as well as the LabVIEW runtime engine. Any ideas?
Thanks!
Paul
Message 1 of 1
(4,396 Views)
