Wireless Sensor Networks
Problem configuring mib600 in moteview
Hello everyone,
I have a gateway mib600 the crossbow and wanted to work initially using the toolmoteview. It is the first time working with wireless networks sensosres. When trying to add the following mib every step of the manuals, the moteview, when trying to access mib, it responds with an error message:
[MV: 24/04/2012 08:59:46]
System.Net.Sockets.SocketException: No connection could be made because thetarget machine actively refused
    at System.Net.Sockets.Socket.Connect (EndPoint remoteEP)
    at XBow.lib.XSocketBase.Open (String host, Int32 port)
And the icon theme continues with the gray warning that the device is not accessible.
Please, if anyone knows how to solve this problem I would be very grateful.
(5,907 Views)
Hi Irlan,
Which National Instruments Software or hardware would you like to use in your Application. Are you intending to use a Instrument Driver to communicate with LabVIEW, for example?
Regards.
Felipe Flores
Technical Support Engineer
(5,849 Views)
