Wireless Sensor Networks
Need help
Im a newbie here and ive just bought wsn 9791. Ive design a labview the same exact way as the starter kit recommends (basic stuff just to test out) and when I click run this error pops out.
Connection failed.  The network address might be invalid or the target is not responding.
My both of the notes are on as i can see the connection through max so is it because of invalid ip adrress? but in max it says connected-running. Anywya thanks for your help.
(11,041 Views)
ignore this thread. Just found out that my pc ethernet port is spoil. cheers
(11,035 Views)
lol 🙂
(10,623 Views)
Same problem here. Still unsolved till now.
(8,910 Views)
Hey btatmaja,
I think that you need to follow the document carefully and also be sure about the ethernet connections and IP address assigned to PC
thanks,
Abhinav
(8,889 Views)
