Wireless Sensor Networks
Battery health -> transmission output
Does the battery voltage affect the power output of the WSN nodes?  In other words, does a weak battery affect the wireless transmission distance or the voltage applied to the sensors?
Garrett
(7,378 Views)
Hey Garrett,
The node will function the exact same way until the battery is depleted.  You should not see a drop in transmission power or output voltage.
Kevin
WSN/Wireless DAQ Product Support Engineer
(7,377 Views)
