Washington Community Group
Seattle LabVIEW User Group Meeting - 2023
Fresh Consulting also has an office in Portland, OR at 811 SE Stark St Suite 300, Portland, OR 97214. I will be hosting an in-person remote viewing session for the meeting at our Portland office. We will sign into the meeting and watch remotely on a projector. We can then have our own in person discussions and Q&A.
Please let me know if you have any questions.
Message 11 of 17
(3,140 Views)
Hi all
Do you have a registration link or a teams link for this meeting?
regards
Message 12 of 17
(3,121 Views)
Here is a link for those who wish to join remotely:
https://freshconsulting.zoom.us/s/89636000665
Message 13 of 17
(3,111 Views)
Thanks Andy!!! Posting more details below for reference:
Agenda:
6:00 to 7:00: Networking and Pizza
7:00 to 8:30: Presentations and Q&A
8:30 to 10:00: Wrap up and open discussion.
o  Seattle location- 14725 SE 36th St #300, Bellevue, WA 98006
After 6:00 park in the lot next to Fresh Consulting as the garage gates may be down and proceed to the front door for entry.
o  Portland location - 811 SE Stark St Suite 300, Portland, OR 97214
Reach out to @Andrew phan
To view the presentation remotely, here is the Zoom Link: https://lnkd.in/g53MQu9d
Message 14 of 17
(3,052 Views)
Fantastic.  I plan on using the zoom link to join remotely from home.  Looking forward to virtually getting together and sharing cool stuff.
Warren
Message 15 of 17
(3,046 Views)
You can find the Demo and Slides I presented from last night attached.
The power supply I used was a BK 9205, the DMM was a Fluke_8808A, and the Arduino was an ArduinoMega (its code is also included).
You should be able to implement your own instruments using the same interfaces, add (or replace) your class at the starting array, and have the code work as expected (initialize, set the output, read the voltage[s], close) when you run it.
Another item was brought up that I had forgotten to mention regarding interfaces: If you work toward SOLID principles, correct use of interfaces helps with the D (Dependency Inversion), in that your code no longer depends on a specific instrument or method of performing a function, but instead depends on the interface to that function (these are the inputs, those are the outputs, I don't care how it's implemented), and makes the core parts of your code that much more portable.
Thanks for the reminder, John! This is another important aspect of OO that should indeed have been mentioned last night!
And thank you all for coming, it was great to see everyone!
Message 16 of 17
(3,021 Views)
Thanks for sharing Chris!!! I really enjoyed your presentation.
Also wanted to follow up on your LabVIEW "dark mode" comment...
Message 17 of 17
(3,015 Views)
