Version Conversion
Convert from 25.0 to 20.0
The file is not opening on 2020 version.
(1,414 Views)
Error -
LabVIEW: (Hex 0x465) File version is later than the current LabVIEW version.
An error occurred loading VI 'Aircon_GUI_Main.vi'. LabVIEW load error code 9: VI version (25.0) is newer than LabVIEW version (20.0).
Does anyone has access to Labview 25.0 ?
(1,458 Views)
You can post your VIs at the Version Conversion board
(1,436 Views)
Yes, some of us do.  But we cannot convert your VI (in LabVIEW 20.0) if you don't attach it to your Post.
(1,427 Views)
Can you convert these from 2025 to 2020
(1,405 Views)
No, I can't, because I don't have LabVIEW 2025.  But you can, because there is a "Version Conversion" Board here as part of the LabVIEW Community.  If you go to Version Conversion Board and follow the directions, they will do the conversion for you.
(1,346 Views)
