Version Conversion
Conversion from 5.0.1 to something modern
I have some legacy LabVIEW code from my previous projects that I would like to convert to something useful within current LabVIEW versions. While using this file conversion blog to have posted code converted is obviously useful, I would prefer being able to convert my legacy code at will. Previously I found a VI Converter from NI to do just that, but the converter no longer seems to exist and I can't find the version I had. It seems that if I had LabVIEW 8 installed, it would be useful as a stepping stone converter but I haven't found a LV 8 installer either. Nevertheless, would someone with the necessary tools convert the attached files for me.
Old version: 5.0.1
Thanks in advance.
Note: the .zip files are broken up into chunks less that 10 MB due to upload restrictions.
(498 Views)
Accepted by crossrulz
Mass compiled it in LV 8.0. You can read this in any higher version.
Kees
(470 Views)
Perfect. Thanks.
(452 Views)
