VeriStand
hardware discovery wizard error
Hi
I have installed Veristand 2014 on my PC connected to a NA PXI8109 including 1 PXI-2571 and 1 PXI-6514: when I start the Hardware Discovery wizard I got the error message attached; I verified via NI MAX the software on both devices (PC and PXI) and they are aligned and complete; from NI MAX I correctly detect the hardware configuration: is there something I am doing wrong ?
thanks
francesco
(4,814 Views)
Hi Francesco,
did you install VeriStand Engine on PXI RT Controller?
You can try to manual add DAQ device to your system definition file. You need specify the same device name you read from Measurement and Automation Explorer.
Here you can find some interesting Demonstrations about how configure VeriStand Project System Definition file.
Hope this will help.
Kind regards.
Claudio Cupini
National Instruments Italy
Application Engineering
(4,786 Views)
Hi Claudio
thanks for your suggestions !
I reinstalled all the drivers NI DAQ and NI SWITCH and it is working !
regards
francesco
(4,774 Views)
