VeriStand
define path for .NET controls
Hi to everyone,
so this is my problem: i have to build a custom control in veristand. i created a labview code for it. so, when i click down the mouse in the workspace of veristand, appears a windows where i can select my path of control. Now, i don't want to select it, but i want define it "a priori" inside labview, so this path is also visible in veristand, but here it is not modifiable.
i m very happy if someone could help me.
thank yoy so much in advances
Mauro
(6,049 Views)
Hi Mauro,
You can't "block" the control in Labview but you can try to keep the control in "Disable and grayed" mode and after that import the custom control in Veristand. Do you see the same behaviour? Have a good time!
Kind regards,
Enzo
(6,014 Views)
Hi Enzo,
so, i done it. But now the path that i select it is no visible. if you check my vi, u will now this one, it is very strange.
my aim is to insert the path in the Channel and disable it.
thank u in advances, i hope to resolve it as soon as possible
Mauro
(6,006 Views)
