VeriStand
Veristand Error 1
Hi All,
Here is the situation:
I am using LV2012 SP1, NIVS2012, DAQmx9.8
I have got Error 1 every time i open veristand:
When i click continue and try to open project, i have this error message:
Host PC situation:
- No other one logged in exept me
- I have restarted host-pc
- I have rebooted RT-Controller
- Error 1 still exist when veristand is opened. Error 1172 is also popped up when i open project.
- I have reinstalled NIVS on RT-Controlller, but errors are still occured.
So, this link which has similar problem with me, won't help.. ;(
What i did before to resolve this problem--> Reinstall NIVS on PC-->No error occured after sometimes.
Question:
- Anyone can help how to resolve the problem?
- Shall i reinstall again NIVS on my PC?
Thank you for your help,
Rajamodol
(6,818 Views)
Hello Rajamodol,
some thinks you can test
1. under services.msc shutdown the windows firewall
2. check if Net framework 4.5 or later is installed
3. check if a second instance of VeriStand is running
4. Install latest patches
If this not helps reinstall the software on the PC
1. deinstall the NI software from your
2. delete the folders
3. clenup registry
4. start with a fresh installation
Sorry for this.
best regards
Alexander
(6,785 Views)
Hi Alex,
thanks for your reply..
I have just reinstall back my LV2012, TS2012, and VS2012, and also DAQmx9.6
When I open MAX, i got this error....
That error is not explained in the this link
Any idea?
I would be very thankfull for any help...
Rajamodol
(6,780 Views)
Hello Rajamodol,
you can reset the MAX
How Do I Clean a Corrupted Measurement & Automation Explorer (MAX) Database and Start With a New One...
or try to update the System Configuration Software which brings a newer MAX version.
Hope it helps
best regards
Alexander
(6,767 Views)
Hi Alex,
thank you for your guide!
I have once again remove all NI product installed on my test system, it means deleting directory National Instrument under "C:\Program Files (x86)\". I used also msiBlast.exe to clean up registry.
I installed LabVIEW 2012 SP1 and upgrade it to LV2012 SP1 f5... it's ok until this point.
I opened MAX to see my PXI. Then the same error occured. As your suggestion, i cleaned up MAX database. But, it didn't help.  Same error, my RT-Controller was detected, but no chassi.
I try to upgrade NI MAX to the newer version.. then i got this error message during installation:
I am really frustating now.. 2 days just for reinstallation and no progress...
Any help/ideas would be very appreciated!!
thanks again,
Rajamodol
edited:
I have admin right on PC.
(6,745 Views)
Accepted by topic author rajamodol
Hello Rajamodol,
have you tried to stop the service manually
Start --> type "services.msc" and search for the NI Service and stop them manually.
best regards
Alexander
(6,740 Views)
Hello Alex,
Thanks for your help. That way must be work also. Your college fron NI has helped me also..
I am going to install NI Veristand to test system.. let's see what will happen..
I'll post the result then...
Thanks again,
Rajamodol
(6,735 Views)
