VeriStand
Veristand 2020 R4 Error 1003 when launching Veristand after Install
My team has use NI Veristand in the past.  We recently purchased a new HIL system and after installing Veristand the following error is thrown
Error 1003 occurred at GSW.lvlib:Launch VeriStand.vi >> VeriStand Application.lvlib:VeriStand Root Loop.vi >> NI VeriStand Gateway Loader.lvlib:Gateway Loader FG.vi
Possible reason(s):
LabVIEW: (Hex 0x3EB) The VI is not executable. This error may occur because the VI is either broken or contains a subVI that LabVIEW cannot locate. Select File>>Open to open the VI and verify that you can run it.
This occurs every time veristand is launched and is preventing communication to the RT controller.
Any thoughts or suggestions?
Message 1 of 1
(2,526 Views)
