VeriStand
Usage of deltat() / deltaus()
Hello NI community!
While looking for the best way to measure a time difference (much like tic toc in Matlab), I came across the  deltaus() function for realtime sequences. The description of which is "Returns the duration of the current system timestep in microseconds."
What does this mean exactly? What is meant by "system timestep"?
Btw. my current implementation for measuring time difference is:
startTime=tickcountus()
DO SOMETHING
deltaT = tickcountus() - startTime
would it be better to use seqtimeus() or maybe even deltatus() here?
Greetings,
MaWei
(3,050 Views)
Hi MaWei,
System timestep simply indicates the smallest detectable incremental change of your time information. This would depend on your configuration of course. If you call this this function on different architectures, you should get some different results.
Regarding the second question, if you are trying to measure the time that a code portion takes to execute (known as benchmarking), your code looks fine. You are simply taking the difference of two time stamps via counters.
Cheers,
Bart
(2,821 Views)
