VeriStand
Tracing Execution time of a Veristand Simulink Model in Real Time Execution Trace Toolkit
i am using an simulink model containing 2nd order z - transform in veristand as dll. i want to know the execution time of that model in my RT.
for that i made a trace enabled flag to true in veristand workspace and i got the trace results file in "c:/ni-rt/NIVeriStand/ExecutionTraces". i opened that file in Real - Time Execution Trace Toolkit. i found veristand engine and veristand RT etc, but i haven't found the model in that. Help me to find out the execution time of a model in veristand engine.
vikas.
(3,290 Views)
In the thread view of your log (enable the thread flag in the veristand channels), you should find a timed loop corresponding to your model.
That being said, I would go for a much easier solution. For a given model, there's a Time Step Duration channel created under the "Execution" category of that model. It returns the execution time in microseconds. It has several advantages: you remain in the NIVS environment, you can map that information to something else, you don't decrease the system performance and reliability (which the trace tool does - even if that is usually a minor effect)...
--Eric
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
(3,255 Views)
Hi Eric.M,
Thanks for your reply.
my problem is not only about the execution time, i want to validate the veristand model execution order with Real time Execution Trace toolkit. for example i have 15 models in my veristand project and i have given 4 cores of processor to them and execution order will be some are in parallel and some are sequential. so i want to verify that and prove it to the customer whether the execution order is maintained properly or not.
help me in sorting out of that problem.
Vikas.
(3,252 Views)
