VeriStand
Stimulus Profile Editor
The Stimulus Profile Edit in NI Veristand2010 is completely different from NI Veristand2016.Now I want to add several signals in Stimulus Profile Edit 2016(eg:Ramp,Dwell),but I can't find them.What should I do?
(2,534 Views)
Accepted by topic author bhyy
If you look in the Sequences window (lower left) and go to RT Sequence Library -> Standard -> Timing you will see WAIT (this is same a dwell).  If you go to RT Sequence Library -> Standard -> Waveforms you will see Ramp.
Best of Luck,
Josh
(2,461 Views)
