VeriStand
Simulink
Hello.
I created a model in Simulink. This model are calculated in real-time on host machine with Linux. Everything is ok. But I see that only one CPU is loaded. What is the problem can be and how can I fix it? I see the settings were I can choose the processor number for calculation (see the attachment), but it’s only one processor. How can I use several processors for calculation one model? Thank you.
(562 Views)
To my knowledge, a model can only be assigned a processor. You need to split the model into multiple models in order to run them on different processors.
https://tmesystems.net/
(522 Views)
Hello. Thank you for reply.
Is this a feature of the Veristand? I understand correctly? When I run the model in Simulink, all processors are loaded.
(510 Views)
