VeriStand
Scripting function in VeriStand Logging Specification
I would like to run an executable when my logging specification ends. The only documentation I can find on this is what's in the dialog: "Script (use %s for file path)". Can someone help explain what that means? What is the syntax for this and is there any other help documentation on this?
(654 Views)
Running a Command Line Script
It accepts a VBScript. The %s is the file path of the resulting log file. You can use it as an argument to your exe.
https://tmesystems.net/
(625 Views)
