VeriStand
Programmatically change user account
Hi all,
I want to change users from within Veristand while a configuration is deployed and running. Is this possible? If it requires a custom LabVIEW extension that is fine. I just need to know what the functions are that I can use to manipulate the user accounts.
Dave
(4,199 Views)
One way to do this would be to disconnect the host PC/workspace from the RT machine using the API WorkSpace->Disconnect from System.vi.  You could then use API Project->Open Project.vi to specify the user, then Project->Execution->Connect Project.vi to connect your project to the running RT.  I haven't tried this, but using the Project API's should allow you to do what you want.
Good Luck
(4,181 Views)
That isn't quite as clean a mthod as I was hoping for. Maybe that's why Veristand doesn't provide a change-user  function in the user interface. Thanks for your input though. I'll see if the disconnect-reconnect will work.
(4,174 Views)
